Notify About Ralink Technology Corp 802.11n Wireless Lan Card Driver And Its OS
Hello, notify about the ralink technology corp 802.11n wireless lan card driver and notify the OS supports for it too. Thanks as well.
Hey, the ralink technology corp 802.11n wireless lan card driver has the latest version like v 5.0.57.0. Also it checks with the drivers already installed or notify to update the same. Also if some error occurred may fix them too. It has new functions after the upgrade is done. Size of the file will be not more than 10-15 Mb respectively and can get easily get over the internet. The supports OS are:
• Window 7
• Windows 10
• Windows Vista
• Windows 8 or 8.1 etc.
If you are looking for a download for the driver of this wireless network adapter, try downloading Ralink 802.11n Wireless LAN Card. This driver is intended for Ralink 802.11n wireless LAN card or adapter which is common to laptops. Another download for this driver is from HP Support Center: Ralink 802.11n Wireless LAN. This one supports Windows XP, Windows Vista, and Windows 7.
You can also try the download from PC Pitstop: Ralink 802.11n Wireless LAN Card. The wireless “n” standard has a theoretical maximum transfer rate of about 300 mbps with two antennas and can reach as high as 450 mbps on three antennas. But the more accurate speeds are normally around 130 mbps or slower. The 802.11n standard operates at both 2.4 GHz and 5 GHz bands.
