Notify For Offsite Backup Solutions For Small Business And List Features
Hell, notify about offsite backup solutions for small business and states its main features for it as well. Reply ASAP and thank you.
Hello, the offsite backup solutions for small business can be done though the cloud services as well. If a good backup software is used it then give you 2 copies for the same i.e. one copy will be the local one other will be the offsite one. Also it gives you storage limits in Gb and Tb depends upon the service you go for. It also provided full data security as well. Below shows it key features:
• Gives access to the file managers.
• Also can go for selective backup instead of all data.
• Also provides you with automatic backup services.
• Keeps the record for the scheduling the backup in a week.
• Also has PC as well as Mac file backup too.
Notifications
