Notify For The Scan Mac Address On Network With Features
Hello, notify the scan mac address on network with its features too and its file size for it and reply soon for it and thanks for solving too.
Hey, the file size for the scan mac address on network will be not more than 30 Mb and can be easily downloaded over the internet. Also it is supported for the various OS of windows as well. Also it scans the Mac address with the help of the network used over it. Below shows the key features for the same:
• It has easy access to the networks as well
• Can export the scan file to the CSV
• It detects the mac address to.
• There’s no need for the installation of it
• Can be easily handle over the remote control too
If you are looking for an application that can scan your network for the Mac address of devices and computers connected to your network, you can use SoftPerfect WiFi Guard. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. For Mac, it supports OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, and 10.12 Sierra.
This application is free for Microsoft Windows but not for OS X, costs $9.99 a license. Among its features include:
Though its name says “WiFi”, the application is not limited to Wi-Fi networks. You can also use it on a regular Ethernet adapter if you don’t have a Wi-Fi adapter installed. To select which adapter it would monitor, in SoftPerfect WiFi Guard, go to “Settings”. In “Basic” tab, under “Network adapter”, select the network adapter you want to track.
On that screen, you can also adjust the scanning parameters of the application under “Scanning options”.
