Notify For The Vb 2010 Access Database Tutorial In Stepwise.
Notify the steps for the vb 2010 access database tutorial in stepwise for the reference only and revert soon for it and thanks as well.
The steps for the vb 2010 access database tutorial is as follows:
• First open the windows forms and connect the data
• Now open the view menu >other windows > data sources
• Next click for the add new of data sources
• Later selected the databases and chose the source type
• In the data connection page select the new connections
• Also can change the connection if it’s the OLE DB
• Later specify the database name in .mdb file
• Later select the choose data connection too
• Now save the connection for the configuration files
• Later choose the database objects
• Lastly finish the process after viewing the datasets.
