Notify Steps For Rdp Printer Redirection Not Working In Stepwise
Hello, notify the steps for the rdp printer redirection not working in stepwise for the better reference only. Thank you and reply ASAP.
Hey, the steps for the rdp printer redirection not working is as follows:
• First open the local PC and open the remote desktop connections.
• Now manually enter the address you want to connect with
• Click for option
• Next click the local resources tab
• Now fill the checked box for the printer in the local devices respectively.
• Next connect the same with the username and password too
• Check for the visibility of the printer on the remote PC
• The printer’s installation is done successfully.
