Notify The 2010 Office System Driver As Guidance Too.
Hello, notify the steps for the 2010 office system driver as guidance as well and thanks you so much for the solutions too, also revert ASAP for the same too.
Hey, the 2010 office system driver is supported in many of the cross platforms OS as well and more of is supported in the windows systems such as in the windows Server, windows 7, windows Vista and also in the windows Xp OS too. Below shows the steps for the same:
First, try downloading Microsoft Access Database Engine 2010 Redistributable and install. It supports Windows XP Service Pack 3, Windows Vista Service Pack 1, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003 R2, Windows Server 2008 R2, Windows Server 2008 Service Pack 2, and Windows Server 2012 R2.
If, after installing Microsoft Access Database Engine 2010 Redistributable you encountered problems, this is probably one of the reported problems that may arise when you’re on 64-bit Microsoft Windows and you are using 64-bit Microsoft Office 2010 and higher. The reported solution was to install “2007 Office System Driver: Data Connectivity Components.” In this case, try downloading 2007 Office System Driver: Data Connectivity Components.
It supports Windows XP, Windows Vista, and Windows 7 including Windows Server 2003 and Windows Server 2008. Its basic function is to facilitate the transferring of data between 2007 Microsoft Office system files and non-Microsoft Office applications.
