Hello, notify the various other solutions for the certificate with thumbprint was not found exchange 2010 and also mentioned for the same in detail as well with its steps one after the other for the guidance too and thanks a lot
Notify The Certificate With Thumbprint Was Not Found Exchange 2010 With Steps.
Hey, the certificate with thumbprint was not found exchange 2010 can be solved by getting the date change over the systems or can try after some time when the date is changed too. Still not solved follow the given steps too:
- First disable the services of the exchange too
- Now can clear the apps and the system logs too
- Also can restart the servers as well.
- Next reinstall the exchange for the SP3 and it’s completed.
