Notify The Oracle Date Difference In Years With Examples
Hello, notify how oracle date difference in years also solve the same with the examples for the easy reference only. Thanks for the same as well.
Hello, find below the example for oracle date difference in years as follows:
To make the changes first select the employee and create a new column for the date respectively. Then from the systems date divide the same by 365 to get the values in years. If supposes there’s 366 days don’t worry it will get round off to the nearest. Then for the line 3 check the query is smaller than 1992 or not. Lastly the year column starts form the bigger year only. See the example below solved for the reference.
