Notify The Project Management Network Diagram Template In Steps
Hello, notify the steps for making the project management network diagram template and mentioned in brief for the same as well. Thank you and reply ASAP
Hey, the project management network diagram template helps to create the business flow diagrams for the various help in the business plans or in the MNCs as well for their work flow etc. also it helps to create the easy structure for the work been in process too. Below shows the steps for the same:
• First insert the tab > illustration group > and click on smart art.
• Next choose the smart art as the graphics gallery > process > picture accent process
• Now add the picture in box if you wish so and then click on the picture icon.
• Next select the picture you want for the display chart and click insert.
• To enter the details in chart click on text pane and type the same.
• Make the work flow as per your wish and it’s done.
