Notify The Replace Dell Laptop Hard Drive In Stepwise
Hello, brief about the replace dell laptop hard drive and also notify the steps for it as well and reply asap for it and thanks for solving too.
Hey, the replace dell laptop hard drive can be replaces easily and can be done manually to and its easy to do so. The replace can be done from the following below steps:
• First you can manually remove the battery.
• Next remove the screws from the doors placed and remove the same as well.
• Also get the 5 screws which are at the primary HDD brackets palace and remove the same.
• Now slide the battery and release the latch too
• Now manually remove the HDD and replace it.
Notifications
