Notify The Steps Restart Remote Desktop Windows 7 In Stepwise
Hello, notify the steps for the restart remote desktop windows 7 in stepwise for the reference only and also thanks for solving and reply ASAP as well.
Hey, the steps for the restart remote desktop windows 7 is as follows:
• First go to the start > all programs > accessories > command prompt
• Next manually type for the shutdown / I for the remote shutdown
• The file will be in shutdown. Exe format
• Next in the computer section go for the ADD for entering the computer name and browse for it
• Later the purpose for it will taken and click to restart it or can go for the shut down as well.
• Lastly choose the correct reason for it and it’s done successfully.
