I have Samsung Galaxy S4 which I received a message that I could update to Kit Kat 4.4.2 and after the installation, Nova launcher won't start, I have tried reinstalling the application but still it wont launch, what could be the problem? How can I get it working?
Nova launcher is an excellent launcher and kitkat compliant. But to run it on kitkat , you may need to update it to Nova launcher's latest version. Hence possible solution could be:-
1. You have everything in place, just try to restore nova launcher, go to settings of Nova launcher, select nova instead of Touchwiz. Restart the phone and you are good to go
2. If you don’t have everything in place that is nova didn’t receive latest update. You need to update it through play store and follow instructions.
The Samsung Galaxy S4 I9500 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on March 2013 and released on April 2013 measuring 136.6 x 69.8 x 7.9 millimeters and weighing 130 grams. It is built with plastic body and uses micro-SIM card.
Samsung Galaxy S4
It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution protected with Corning Gorilla Glass 3. It ships with Android 4.2.2 Jelly Bean upgradable to Android 5.0.1 Lollipop with TouchWiz UI powered by 28 nm Exynos 5410 Octa chipset, Octa-Core processor (4 x 1.6 GHz Cortex-A15 and 4 x 1.2 GHz Cortex-A7), and PowerVR SGX544MP3 GPU.
It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 13 megapixels featuring f/2.2, 31mm (standard), 1/3″, 1.14µm, and AF with HDR and LED flash. It can record video in 1080p at 30 fps with dual-video rec.
The secondary camera supports 2 megapixels featuring f/2.4 and 31mm (standard) with dual video call. It can record video in 1080p at 30 fps. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 2.0 with MHL 2 TV-out and USB Host support.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors: ANT+, S-Voice natural language commands and dictation, and air gestures. It runs on removable Li-Ion 2600 mAh battery with standby time up to 370 hours on 3G and talk time up to 17 hours on 3G. It is available in White Frost, Black Mist, Arctic Blue, and Black Edition colors.
It supports Qi wireless charging. Now, if the app suddenly stopped working after updating the firmware of your phone, just delete the app then download the latest Nova Launcher.
1....
