Hi experts,
I never experienced this type of error message, so having little hard time with this error. I used do this re-installations of printer drivers, for Windows 7 64 bit operating system it got ended up with an error. Deleted all files related to printer installation and also I do the system restore, but nothing worked out. Anyone experienced this error before? Help me to solve this error. Your help is great.
Error:
Novell iPrint
Error message: Unable to find a core driver package that is required by the printer driver package.
Error group: Windows
Error code: -2147021880
Novell iPrint unable to find a core driver package
Ensure that you have the right iprint client for windows 7 64 bit. Iprint is a Novell product (A different operating system). The iPrint Client installed to Windows 7 helps to print application via a Novell NetWare server.  I am assuming that you do not have a local printer available and you have to depend on the Novell Netware operating system and iprint client to print any application. In that case you require getting in touch with Novell system administrator. In other cases, if you have installed the iprint client by mistake then try un-installation of iprint from control panel-> Un-install a Program module by running the windows under safe mode.
