NPPTooks.dll is missing on Windows 7
I am using Windows 7 and suddenly I received and error “NPPTooks.dll is missing from your computer”. I got the following error message when I was installing some software on my computer. Help me to fix this error.
The program can't start because NPPTools.dll is missing from your
computer.Try reinstalling the program to fix this problem.
Best Answer by
Answered By 0 points N/A #176233
Hallo Jeffrey,
Netcut.exe is a malware related file. For the safety of your computer and the files that are on it, you will need to delete that file immediately. Go to the task manager and kill the netcut.exe process and then remove netcut.exe from the windows startup.
Fletcher Hoss
Answered By points N/A #176234
It looks like you are having this issue with Notepad++. Notepad++ is the best text editing tool for programmers with awesome syntax highlighting technique.
In order to solve the issue, I recommend you to get the latest version of Notepad++. Then, run the installation process again.
Also, you can download NPPTools.dll and install it inside your system. This will make your PC the DLL file available and run the program perfectly.
