Nt perfect companion crashes when launched
I have been using Perfect Companion for my Windows NT system as long as I can remember for fixing my system registry.  It recently stopped working and just crashes when launched.  Is this an update problem?  Please help with NT Perfect Companion.  Thanks in advance.
Answered By 85 points N/A #145253
Registry cleaners can sometimes remove essential files that are needed to run certain programs and applications. If a certain windows file was removed it could cause your registry cleaner to stop functioning as it should. A windows system restore should fix the problem.
  • To run system restore
  • Click the windows circle in the left side of the screen
  • Type restore in the box
  • System restore will be in the results at the top
Click on system restore to run it
This window will come up
  • Select recommended restore
  • Click next and follow the prompts
If that does not work I recommend registry mechanic as an alternative registry cleaner,
