andremolina
Posted on - 01/31/2012
While creating the NTBackup in Windows Server 2003 SP2 (which is also the domain controller and exchange server), the network connection aborted and Windows Server shows the error “Generic Host Process for Win32 services has encountered a problem and needs to close”. This is also happening when editing, deleting or even running that NTBackup scheduled file. Due to this problem I can’t ping with the internet server and it also does not work as DNS server and emails got lost and even nobody gets access to the use the internet browser well. Should I need to restart it as I can also see many different events like 1058, 1030 and 2005 or should I have re-install Windows Server again?
Surujkb
NTbackup problem error occur (Generic Host Process…encountered problem)
This happens when some components of windows 2003 are missed or displaced or omitted or even for virus etc.
In this case, it is advisable to restart the computer first. If the problem goes fine. But generally, this problem will not this only in restart of computers.
Secondly, windows can be repaired by installing the system and in most cases this problem will remove and can work properly..
If the problem is still showing, it will require to install a fresh windows 2003. Before doing this, it is advisable to keep the important files and documents of Drive C into another drive. Otherwise all will lost and can't be recover after installing a fresh windows.
This is very simple and straight forward. Just download the code form the following link and run it and that's all to solve or fix the problem "Generic Host Process For Win32 Services Encountered A Problem and needs to close."
https://app.box.com/shared/poxzv7ynk1
You can easily solve the problem Generic Host Process For Win32 Services Encountered A Problem and needs to close. If you face any problem, then put the problem in the comment section.
Have a nice day.
