NTFS or FAT 32 what kind of file i chose
When i setup Windows XPÂ operating system in my computer, at a time its need to select a file system that FAT32 or NTFS. I want to know what kind of system is better? and about NTFSÂ and FAT32
The main thing is that your necessity. Necessity is the mother of invention as the NTFS is found after FAT. NTFS has some additional capabilities like to Index the files and compression technologies. The Security mechanisms can be exercised using the NTFS file system. Groups, Individual owners, or remote desktop users and any user can be given their own permission to use a particular file, directory, sub directories etc.
As such the extensive features lead to a great deal in the modern scientific world where security has its own way to the usage and latest beans for the guidelines in the near future for its pro effect. USE NTFS.
Hello Dear,
These two systems have its own advantages and disadvantages by their side. When I am talking about the stability of hard dish and as well as the files that stored in hard disk, I will prefer NTFS. Although sometimes you just need to use the fat32 system. Earlier, FAT 32 overcomes the lagging of FAT system file. And, now, NTFS file system overcomes FAT 32 with its high speed file transfer system.
FAT 32 involves 137gig limit. You should know that it’s for ATA device. Now SATA devices improved, SO, I will recommend you to use NTFS
Thanks for having your time
