NTI drive backup full software
Hi Guys,
I need a software similar to that of an NTI drive backup full software. Please suggest me a better similar softwares which will be of low cost compared to that of NTI.
Thanks,
Gabrielleriya
Hi Guys,
Thanks,
Gabrielleriya
I’m not sure if NTI Corporation is still updating their backup utility program NTI Drive Backup! because the program’s latest and last version was 4.0.20 which was created in May 2005. NTI Drive Backup! has 3 different versions and they are versions 2.0, 3.0, and 4.0.20. If you want to check them out again, visit NTI Drive Backup!
Aside from NTI Drive Backup!, there is also another program called Paragon Backup & Recovery 2013 which offers the same functions and benefits. For its backup function, it offers Complete Backup, Differential Backup, Backup Scheduler, Backup Capsule, Any backup destination, and Automatic data exclusion. For the recovery function, it allows you to completely restore your computer to an earlier state.
If you want to restore a particular drive only, you can do the restoration by separate partitions, select the files you only need, or restore the entire drive. To know more about it, visit Paragon Backup & Recovery 2013. Another similar application is the AOMEI Backupper. It has a very straightforward interface that will allow you to understand and use it more easily.
Just select the drive to backup, set the destination of the backup file then click to begin the backup. Visit AOMEI Backupper to download your copy. See image.
