Number of PCI slots on computer?
It is not possible to increase the no of PCI slots unless your Motherboard is designed with some extra slots such that you can use those slots when required but unless it is not provided you cannot increase the slots because it entirely deals with hardware .You can upgrade your motherboard for the more number of slots. If u do not want to upgrade you can buy conventional PCI card which has different no of PCI slots depending on the manufacture.
This is the image of the PCI card
Hello Smith,
The only way that you can use to increase the PCI slots available on your computer is to but another PCI interface that has slots compared to the one that you have now.
But most PCI interface cards come with a considerable number of slots that will allow you to add more cards like the network card, TV card and several others, You might just want to check that on the one that you already have and see if there are slots that are unused before you consider purchasing another PCI card.
Hope this helps.
__
Regards
Lee Hung
