Hi friends,
I am using HP Printer Deskjet 1010 model and it was working fine.
But from last week, whenever I am printing something it is printing random numbers on the first page. I have checked the settings several times and there is nothing related to this behavior. I have restarted the machine several times, but still no luck. I had wasted lots of paper.
Did anybody face this kind of problem? If so, please help me in resolving this issue. Thanks a lot in advance!
Numbers are being printed using HP printer
Hi Adam!
Indeed, such experience is new to me too. I never had problems similar to that. I hope I could see a sample of the print output, but I'm thinking it may be similar to that picture below.
So your report revealed that the printing of the random number suddenly appeared. If this is not a hardware issue then it must be a software. It's hard to get out from speculation like I have since I only rely on my imagination of your description.
To check which of these are possible, try installing the printer to another computer and see if the errors will be repeated during the printing. If there are no similar observations, then the printer is okay and you need to check your computer, its software, or reinstall the printer; otherwise, the problem is most likely in the printer.
If the printer was reinstalled and the problem recurred, then the problem is most likely due to a software conflict. This may call for reinstalling the operating system and ensure that it is secured by an anti-virus software.
On the other hand, you may try the procedure of addressing the problem promulgated by the HP website. Click here for details.Â
I hope this could help you.
