Numbers to Words in hundred and Millions
I have copied the following code from this site, it's working properly, but it converts numbers in the thousands and Lakhs. I need the same code to be converted numbers to Hundreds, Millions and Billions format. Can someone Help me in this regard? Thanks in advance.
Function Ntow(amt As Variant) As Variant
Dim FIGURE As Variant
Dim LENFIG As Integer
Dim i As Integer
Dim WORDs(19) As String
Dim tens(9) As String
WORDs(1) = "One"
WORDs(2) = "Two"
WORDs(3) = "Three"
WORDs(4) = "Four"
WORDs(5) = "Five"
WORDs(6) = "Six"
WORDs(7) = "Seven"
WORDs(8) = "Eight"
WORDs(9) = "Nine"
WORDs(10) = "Ten"
WORDs(11) = "Eleven"
WORDs(12) = "Twelve"
WORDs(13) = "Thirteen"
WORDs(14) = "Fourteen"
WORDs(15) = "Fifteen"
WORDs(16) = "Sixteen"
WORDs(17) = "Seventeen"
WORDs(18) = "Eighteen"
WORDs(19) = "Nineteen"
tens(2) = "Twenty"
tens(3) = "Thirty"
tens(4) = "Forty"
tens(5) = "Fifty"
tens(6) = "Sixty"
tens(7) = "Seventy"
tens(8) = "Eighty"
tens(9) = "Ninety" FIGURE = amt FIGURE = Format(FIGURE, "FIXED")
FIGLEN = Len(FIGURE) If FIGLEN < 12 Then FIGURE = Space(12 – FIGLEN) & FIGURE End If If Val(Left(FIGURE, 9)) > 1 Then Ntow = "SAR " ElseIf Val(Left(FIGURE, 9)) = 1 Then Ntow = "SAR " End If For i = 1 To 3 If Val(Left(FIGURE, 2)) < 20 And Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & WORDs(Val(Left(FIGURE, 2))) ElseIf Val(Left(FIGURE, 2)) > 19 Then Ntow = Ntow & tens(Val(Left(FIGURE, 1))) Ntow = Ntow & WORDs(Val(Right(Left(FIGURE, 2), 1))) End If If i = 1 And Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & " Crore " ElseIf i = 2 And Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & " Lakh " ElseIf i = 3 And Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & " Thousand " End If FIGURE = Mid(FIGURE, 3) Next i If Val(Left(FIGURE, 1)) > 0 Then Ntow = Ntow & WORDs(Val(Left(FIGURE, 1))) + " Hundred " End If FIGURE = Mid(FIGURE, 2) If Val(Left(FIGURE, 2)) < 20 And Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & WORDs(Val(Left(FIGURE, 2))) ElseIf Val(Left(FIGURE, 2)) > 19 Then Ntow = Ntow & tens(Val(Left(FIGURE, 1))) Ntow = Ntow & WORDs(Val(Right(Left(FIGURE, 2), 1))) End If FIGURE = Mid(FIGURE, 4) If Val(FIGURE) > 0 Then Ntow = Ntow & " & " If Val(Left(FIGURE, 2)) > 0 Then Ntow = Ntow & Val(Left(FIGURE, 2)) & "/100" End If End If FIGURE = amt FIGURE = Format(FIGURE, "FIXED")
Ntow = Ntow & " Only "
End If
End Function
' FUNCTION NTOW '
' MODIFIED BY CYBERT87 '
' A.K.A. GILL BROS @ TECHYV.COM '
' IF YOU HAVE SOME QUESTION '
' FEEL FREE TO MAIL US AT '
' [email protected] '
' OR VISIT OUR WEBSITE '
' http://honeybytes.blogspot.com/ '
