Nvidia 6800 Ultra Graphic Card error
i have a NVIDIA 6800 ultra and I don't know what the problem is.
I can't update my drivers. when I launch battlefield 2 it gives me the NVIDIA drivers option. when i click on the option it goes into the NVIDIA display setup.
I keep getting this error message:
The NVIDIA setup program could locate any drivers that are compatible with your current hardware. Setup will now exit.
Best Answer by Peter franklin
Answered By 0 points N/A #120313
Hi There Sasha,
I strongly recommend you download the specific video card driver for your graphics card. You might have the generic windows driver which does not fully support all the settings of your Graphics card.
I suggest you go to this link and have the website scan your graphics card to find the right drivers.
Please see guide below.
http://www.nvidia.com/Download/index.aspx?lang=en-us
Answered By 10 points N/A #120314
Its just that your Graphic drivers for Nvidia 600 Ultra are not installed. If you are not sure which drivers to install or you are not able to find the right drivers then you should try using the Nvidia Smart scan, it will automatically search for the latest drivers for you video card. Just go to this link and start scan http://www.nvidia.com/Download/Scan.aspx. This will search for the latest drivers and you can install them easily.
Peter franklin
