NVIDIA Card weird Performance issue
Asked By 7060 points N/A Posted on -
I'm having an issue with NFS games. I think its related to Nvidia card. One of my friend is also having the same issue with his nvidia card. The issue is, I cannot steer my car to the left side when i apply nitrous. It goes to the right side when i apply nitrous, but not left. It happened same with the latest game NFS RUN. It happened with my friend's computer (nvidia card) for NFS Hot Pursuit and Most wanted also.
Best Answer by brionas brain
Answered By 25 points N/A #82421
I have formulated solutions for the problem you are experiencing, If you can please post your computer hardware specifications for me to give a better solution on your problem.
1. Please update your video card software look it on http://www.nvidia.com/page/home.html
2. Look for game updates on NFS maybe it is a bug on the game.
3. Check the system requirements of NFS that you are using if it is compatible with your system.
4. Did you try on other racing games if it do the same?
I hope that it will help you to solve your problem and we are here to help you hope you enjoy your stay here.
Answered By 590495 points N/A #317135
If you successfully installed “Need For Speed” but you can’t play it, first to check is the game requirements. Check the system requirements and make sure your computer meets those requirements. Need For Speed supports 64-bit Windows 7, Windows 8.x, and Windows 10.
It requires Intel Core i3-4130 or equivalent AMD with 4 hardware threads support or faster processor, 6 GB RAM, Microsoft DirectX 11-compatible video card with 2 GB video RAM (NVIDIA GeForce GTX 750 Ti, AMD Radeon HD 7850, or better) with Pixel Shader 5.0 and Vertex Shader 5.0 support, and 30 GB free space. If your computer meets the requirements, try updating your video card driver.
The following are the websites of popular computer and video card manufacturers. If your video card or computer is one of these, download the driver from here:
