Nvidia Control Panel Access Denied
Why am I unable to access the control panel? Why is this issue arising? How can this be installed? I want to apply changes in the program?
The NVidia control panel access is denied due to the changes that are being made mostly in the Manage 3D setting section. It also occurs due to the defaults in the graphic processor for a game on the computer. It is related to the driver’s issue. So, it needs an update version and you may be using the outdated. It may be that the Administrator permission may be lacking from the NVIDIA control panel client. To fix this error you can clean install the NVidia’s driver. You can do this by going to the start menu, type “Device Manager” or press Windows key +R or key combo to bring up the Run dialogue box.
Type ‘devmgmt.msi” then press Ok. To update the video card driver expand the Display Adapter click on the graphics card and uninstall the Device. Confirm the uninstallation process then go to NVIDIA’S official website and search for your graphics. You will see a list of related files. Once you find the entry required to save and open it. Follow the instruction box.
