NVIDIA Control Panel Application, 2.8.313.07
I use NVIDIA PCI express graphic card .When I tried to navigate and video control panel  it shows the following error. dew to the error I can not resize screen resolution or can not  change brightness or contrast have latest direct X.
Please  let me know if you know the solution.
           Microsoft Windows
    has stopped working
    A problem caused the program to stop working correctly.
    Windows will close the program and notify you if s solution is
    available.
                                                               Close program
Thanks,
Nathanel
Answered By 0 points N/A #92234
You could have a problem with your program or you have to many processes and forced to turn off almost all of them.
Solution 1:
Go to task manager and then click processes tab. Then end process all of the processes that you don't necessarily need. Also don't overload your process to stop this kind of error.
Solution 2:
It can be a corrupted program as well so start reinstalling the program again to fix the error.
Solution 3:
Check for viruses that may have affected the performance of your NVIDIA software. Scan it using an anti virus installed in your computer or install a licensed one. You can also use the Microsoft Security Essentials which is free for all genuine Microsoft Operating System.
