It is noticed that Many users have reported that the NVIDIA control panel, which is responsible for helping users to control the properties of the GPU, is missing from the Start menu or from the desktop. What are some of the suggested ways to fix this flaw?
baitan
NVIDIA Control Panel Issue
These are some suggested ways of solving this problem:
1) The first suggested way is to Restart NVIDIA Graphics card driver by opening run dialogue box and then typing service.msc and pressing enter. Search a service whose name starts with NVDIA and Right click it and press restart.
2) You can also update the device driver. It can be done from the device driver adapters found in device manager.
3) You can also re-install the driver by first uninstalling it from the device manager and then downloading the driver software from NVIDIA download drivers. Make sure that you are downloading the right version for the right model. After downloading, install it.
4) If none of the above methods work, report the flaw at NVIDIA forum. This way, you can bring your problem to the developer’s notice.
Hope your problem gets solved by one of the above-mentioned methods.
Thank You.
