Jessicca
10 points
Posted on - 12/10/2011
One of my components is Nvidia.
Currently I started using Windows 7 32bit, until now I didn’t had any problems with it.
Before I had Windows XP, but I wanted to try Windows 7.
My friend came to help me with installing components, and whenever we try to install NVIDIA display driver error appears.
Did anyone have this problem?
How can I fix this?
Thank you
Jess
NVIDIA Display Driver v197.13 – English Package error
Non 7-Zip archive.
OK
NVidia display Driver English package error
Hi!
This error is due to corruption of this file or if any virus attacked on it.
Scan this file with registered antivirus. If problem persist after scanning
Just go to
http://www.nvidia.com/page/home.html
Click on support and downloads. Select drivers download. Find your nvidia model
And download the fresh copy of it.
lee hung
75 points
This problem may arise if this "English Package" is in rar format. Can you please check if you have Winrar installed on your computer? If no, please download and install Winrar and try re-installing nVidia components.
If this fails, you may download and install the latest nVidia drivers from:
The "NVIDIA Display Driver v197.13" seems to be compatible with Windows 7 64 bit version. For Windows 7 32 bit version, the above mentioned link provides the latest stable release from nVidia.
Hi Jessicca
Side by side these solutions also check out this Techyv post "Unable to install a program" for more information about this issue.
