NVIDIA GeForce GT Running Problem
I’ve recently bought a new graphics card GeForce GT 440. Every time I play 3D games the first problem that I encounter is the game will lag and then there will be a green and sometimes black line on the left screen. I have an updated driver for this which I’ve got directly from NVIDIA web site. I don’t have any problem with my 2 GB RAM.
I hope someone can help me regarding this problem.
Answered By 5 points N/A #142353
Hello! Can you also post what operating system you are using? Did you immediately experience this problem with your new video? It is possible that your new video card might be defective since you mentioned that you already have the newest drivers from Nvidia. If it is indeed a hardware problem and your video card is still under warranty, then I suggest you go back to the store and have it checked or better yet replaced. But before you do that I would suggest that you download a diagnostic tool that can perform stress tests on your video card to see if it encounters errors. You can search the web and download a diagnostic tool of your preference. I personally use OCCT if I suspect a video card problem. Hope this helps.
