sknavik
Posted on - 08/08/2011
I have just got Nvidia GeForce GT555M as I want to install & play Call of Duty 4 and wants to play at its best. I have window xp SP3 and want to know is it this going to impact the performance? Which OS would be the best to solve the purpose…??
Nvidia GeForce GT555M compatibility issue
Hello Sknavik,
I love playing Call of Duty, it gives me sense of duty of the game I played. Unfortunately, for you, you have some issues installing Nvidia Geforce GT555M. This Geforce GT555M will surely enhance the graphics of your computer to see clear and nice color picture in your monitor. I love having this with my computer.
Here are some tips to;
Go to Nvidia website to update the driver of this card. Your Windows XP might have no driver installed. See link below:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Select you’re computer specification and the type of driver needed for your Nvidia Geforce GT555M. Once installed, you should be able to play Call of Duty with this type of card with maximum graphical images, clear and picture perfect.
Hope this help.
There is no problem with your graphics accelerator as long as it has a minimum of 256 MB video RAM you can play Call of Duty: Modern Warfare 2. The minimum video card that you can use is nVidia GeForce 6600GT or ATI Radeon 1600XT and the recommended is nVidia GeForce 8800 or ATI Radeon HD 2600.
There is actually no problem if you are not using the required graphics card as long as it has enough video RAM, you can always try. If you are not sure whether your video card is supported, there will be no problem if you decide on installing it. This is actually the best way to know if there is something wrong with your machine.
Let the computer decide if the game can be played or not. It will display the problem in case an error is detected. This is the only time you will know what part or parts need to be upgraded. For your video card, visit nVidia and then check if there available updates for your video card’s driver.
Call of Duty: Modern Warfare 2 supports Windows XP, Windows Vista, and Windows 7.
