NVIDIA nForce Management Controller message
On booting up my PC I get a notification message that says Windows is trying to install a device driver. On opening the notification I notice that Windows is trying to download the drivers without success. I have Googled the problem but came up with blogs and posts that go nowhere. I am uploading the notification messages to your site.
"Windows encountered a problem installing the driver software for your device."
Update Driver Software- Coprocessor
Windows found driver software for your device but encountered an error while attempting to install it.
NVIDIA nForce System Management Controller
The system cannot find the file specified.
If you know the manufacturer of your device, you can visit its website and check the support section for driver software.
Thank you
SusanS
