OBIEE 10.13.4.1 on Unibox Multiple Errors
Hi everyone! I have a problem with OBIEE 10.13.4.1 on Unix box. When I open BI publisher link from OBIEE presentation services I get the error below:
***Oracle BI Publisher Enterprise***
***Reporting Login: java.net.ConnectException: A remote host refused an attempted connect operation.***
***Error Details***
***Error Codes:***
Also, every time I insert BI publisher report Object in a dashboard page, I could not go through available BI publisher folders and reports. However, if I enter the Url for BI publisher in a browser I was able to connect to presentation services and build reports, templates using OBIEE metadata. Everything went fine if I go directly to BI publisher, from dashboards link in BI publisher console to the navigation to OBIEE dashboards. Now, the problem arises when I try to connect to publisher from OBIEE dashboards, that’s when I receive the error message shown above. Can you give me any suggestions on how to fix this? Also, I want to know what’s causing this problem to happen. I’ll be waiting with your response. Thank you!
