eri kviars
10 points
Posted on - 07/18/2013
HI All,Â
I Need to know whether Object Desktop Win7 program is a separate package, Do I need to have Object Desktop for Windows 8 seperately. Please do the needful for clarifying as one of my friends told that Object Desktop is a separate suite, which will work in both Windows 7 & 8.
Eri Kviars
Object Desktop Win7 program is a separate package ?
Hello Eri
I might have the answer to your question. Object desktop is a package that contains lots of applications. Some of them are compatible with Windows 8. Others are in the process of being updated.
As long as you have an active subscription, you should not worry about Object Desktop not working.
I hope you will find this information useful.
Randolph
