Object Oriented programming using PHP
I am new to programming in PHP. I want to know if PHP supports Object Orientation and How can I create classes using PHP? Can anyone help me.
PHP supports Object Orientation since the release of PHP3. Further Improvements were made by PHP 4. Since the introduction of the PHP 5 lots of the features of the Object Orientation were included. You could create a class in PHP as the following :
class <<class name>> {
<<private/public/ $property name>> // properties list
//method list
function <<function name>> {
It is same as the other Object Oriented programming. Try it out. If you have any problems leave a comment.
You can create classes and sub classes in PHP 5. Example is given here.
****Implementing Parent Class
class parentClass{
private $parentName;Â //properties can be public, private or protected.
private $parentProperty;
private function1{ //methods also can be public, private or protected.
//statements
function2{
//statements
****** Implementing sub class
class childClass extends parentClass{
private $childName;
private $childProperty;
function1{
//statements
function2{
//statements
For more details you can refer to http://php.net/manual/en/language.oop5.php
Thanks guys. Can I create classes in separate files and link them together? Please let me know how to link and create the objects using it.
Yes it is possible. You can create a separate file for the classes you created and call using following code.
using keyword "require"
require( "class/class_db.php" );
or using keyword "include"
include("class/class_item.php");
*** It is better including each class in a separate file. By that way it is easy to modify the code.
Once you have linked the classes objects could be created using the key word "new"
$obj_item = new class_item();
For further details on creating classes and objects refer to official php site php.net/manual/en/language.oop5.php.
It is possible of linking the classes using the key word "include". And then work as the tutorial to create instances and use the object oriented features.
Thank you guys. It was great help. I think it is possible linking several classes in oe php files and use features of all the classes.
It is possible to link and open multiple classes in same page. Nice to see you got the answer and welcome again to the open source community.
