Object reference not set to an instance of an object
I get the following error message when trying to browse file with File master I installed Net framework already latest version and the game is registered. Can I fix this issue without having any trouble? I would be grateful to you. Thanks in advance.
File Master 12
Unhandled exception has occurred in your application. If you click Continue. The application will ignore this error and attempt to continue.
If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
