ObjectDBX Application In The System Is Giving Acge20.dll Error
What is the acge20.dll error code? Write down the explanation for this error and mention the way to remove it.
Autodesk Inc and ObjectDBX is the software that is developed by Autodesk Inc Technologies, and it is responsible for the acge20.dll error code. The error message received by the user may be in different types, and that is described as below:
The solution to fix the issue is that the user needs to copy the missing acge20.dll file in the system or replace the corrupted file with a new file. The user needs to download the latest version of the file and patch it. The file is available in two different versions to the user and the size of the DLL file is between 1.38MB – 1.49MB.
