Objections shown while attempting to use the remote API
To do the consumer management, I'm attempting to use the remote API's supplied by confluence for every article. I just now pointed the actual SOAP 'stub generator' at the WSDL file, but I am getting objections shown below:
org.apache.axis2.AxisFault: Part'fault' of fault message
'{http://localhost:8090//rpc/soap-axis/confluenceservice-v2}.
Can anybody help me come out of this problem?
Best Answer by Skarbos Jay
Answered By 0 points N/A #146267
Answered By 0 points N/A #146268
I can help you with the error message on your computer. When you get these kinds of Axis faults, I suggest you to check the server log. The client side stack trace may not be detailed enough for you to track down the error. Please try to set the log level of Axis 2 to debug and now you can check for the exact cause.
Thanks and regards,
Skarbos Jay.
