OBS fails to start says d3dx10_43.dll is missing
Hello Tech gamers,
I am new to this Open Broadcast Software, Help me fix this issue. I don’t understand installation went satisfying nevertheless I am not able to start the OBS. When I start the OBS I ended up with system error message. How do I add the dll in the folder? Help me please.
Error:
OBS.exe – System Error
The program can’t start because d3dx10_43.dll is missing from your computer. Try reinstalling the program to fix this problem.
So when I re-install OBS I am getting another error message saying one more dll is missing. Where these dll are going? Why it is missing while installation? When I ignore this message and continue forward I am able to get into OBS. How to solve this error? Please assist me to find the solution. Thanks.
Error:
Open Broadcaster Software 0.51b Setup
Error opening file for writing:
C:Program Files
(x86)OBSpluginsGraphicsCaptureGraphicsCaptureHook.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Answered By 590495 points N/A #185940
With that problem with the DLL file when you attempted to reinstall it, it can be caused by your antivirus locking the file because of an early attempt to launch it. Antivirus won’t normally lock a file if the program associated with it was not opened. In this case, try restarting your computer then after booting disable your antivirus, and then reinstall Open Broadcaster Software.
It should do the trick. See if this is successful. Also, since you are using an old version, you should update to the latest version. Visit Open Broadcaster Software 0.613 Beta to get the latest version. This version includes support until Microsoft Windows 8. In case you encounter a problem running the program, try opening it as administrator.
Right-click on the program’s icon or shortcut on your desktop and select Properties. Select Compatibility tab then check “Run this program as an administrator” under Privilege Level and click OK. Start Open Broadcaster Software and see if it works. The error about the “d3dx10_43.dll” is pointing to the DLL file of Microsoft DirectX.
It is not possible for the DLL file to be missing because Microsoft DirectX is a component included in the Microsoft Windows operating system. If this problem continues, updating Microsoft DirectX will probably solve the problem.
