Obtaining an IP from MSN or Yahoo or any Messenger.?
Hi Mario,
It is very easy to finds some one ip address. Here are the few step which had to run and u had ip address of any on msn or yahoo.
Firstly we learn the method used by most people when they want to get
someone else IP Address.
Step 1 – Start MSN Messenger and login as yourself.
Step 2 – Hit your "Start" button and click run. Type into the white box
"Command" or type cmd(without the quotation marks)
Step 3 – Type in "Netstat -N" (without the quotation marks) into the
black box and hit enter.
Step 4 – Start a conversation with your 'victim' and send them a file.
Once they accept the file Hit your "Start" button and click run. Type
into the white box "Command" (without the quotation marks) and Type in "Netstat -N"
(without the quotation marks) into the black box and hit enter.
Step 5 – Look in the middle column of both your MS Dos boxes and look
in the newer window for the IP address that has magically appeared in
the middle column. This is your victim's IP Address.
Notifications
