HI guys,
I have recently started using Oracle ADF for my mobile application development work and I am impressed by the number of tools that it provides me. What I was wondering is if I can get ocr in oracle adf support such that I can be able to build an application that can recognize natural characters and accept such characters as a form of input.
If anybody has information on this please reply to this post.
Ocr in oracle adf support
Hi Avery. Regarding to your queries on OCR in Oracle adf support, Oracle has its own website, you can get the OCR in oracle adf support and you can use their demo video for you to learn about on how to use it fully. I hope it helps you regarding to your queries.
OCR or Optical Character Recognition, this is a very helpful tool that many are using. It is life a soft copy of the original hard papers wherein you can have them type written in your system. Regarding your inquiry yes OCR can be used in Oracle and it can be configured. I will give you the links for the tutorial and configuration of this OCR to your oracle for more better understanding and full set up to be used in your system. Some of the original fonts will work with OCR on your Oracle.
This first website will help you understand on how to set the OCR on your oracle system.
OCR Config webpage
I also Added another OCR site where you can check the configuration and it will give additional view and knowledge on how to set up the OCR on oracle.
Another reference for config
The last link will give you more understanding on what to do with the first two links that I gave you, the configurations is not just giving you the commands or how to do it. You need to understand it more deeply.
Tutorial for OCR
