OCZ vertex 3 SSD help
I need to buy an OCZ vertex 3 SSD. Can anyone give me the price and other infos about the OCZ SSD ? And I need to know the data transfer rate.
The vertex SSD is a data storage disk. It uses an integrated circuit to store data. Therefore, it has no moving parts inside. This enables it to have a shorter access time and latency. In addition, the SSD has is less susceptible to shock or damage. The OCZ vertex 3 SSD is priced about $200. However, the price may change depending on the retailer. The disk comes with the standard 240-500 GB storage space. It has a data transfer rate of 550mb/s. The drive is compatible with most serial buses. In addition, it shares I/O interface technology with Hard Disk Drives and therefore can be used to replace them.
