Office 2003 and SP3 integration error using ‘Office Integrator’
To integrate sp3 for Office 2003, I am using Office Integrator. It worked excellently. Now this time to integrate the hotfixes, which I am trying to do the exact same, an error message appears
Unable to read C:Documents and SettingsAdministratorMy DocumentsDownloadsoffice 2003 slip streamedfinal product sp3 and hotfixes file. Error code: 0 <ERROR #1<
Do you need my full log? Thank you.
UPDATE: Whole process again was integrated with the hotfixes (3 hours it took) and the process complete without any errors this time.
Win 7 x64 is where I want to test this. I’ll support your efforts if this works.
Answered By 5 points N/A #150307
Hi Suttie, your query seems like another exactly still from the internet! Your error experienced is most probably due to an error with the software.
You may need to go to the troubleshooting option in the Control Panel and try troubleshooting the program.
Open Start->Control Panel->SPE and  click on Troubleshoot in the options
f troubleshooting doesn't work, you can uninstall the software and reinstall by doing the following;
Go to Start->Run
Type 'regedit'
In registry editor window go to HKEY_LOCAL_MACHINE_SOFTWAREMicrosoftOfficeOffice integrator
Delete all the files under the Office integrator
Uninstall the program
You may also go to the temp folder under C:WindowsTempMicrosoft OfficeOffice integrator
Reinstall the program and it should work
Thanks
