mamanzoor
Posted on - 08/27/2012
I was installing the MS office on my PC but it encounters an error during installation. This error that is written in "Office 2010 Encountered an Error during Setup". I need a help in this regard to resolve this issue so that i will be able to install the office on my PC to open the documents on my PC. I am waiting for the prompt reply.
Office 2010 Encountered an Error during setup?
I spent 30 minutes on different sites and I think I found a solution to this problem.
Take a look at this site, read what is written and it may help you out.
http://forums.techarena.in/office-setup/656779.htm
I see 2 problems here: either the previous installation of Office bugs this one, because it remained in your system, or Windows has a bug and it is not working properly. Read the text from the link and tell me if this helps,
regards,
Hi Mamanzoor,
Try to disable your account control. The User Account control could be preventing some changes to your computer (especially if it’s unauthorized). To disable your account control:
1. Click the Start button.
2. Click the Control Panel.
3. Click ‘User Accounts’.
4. Click ‘Change User Account Control Settings’.
5. Move the slider to ‘Never notify’ position. Then click ‘OK’
6. Then, you need to restart your computer before the User Account Control turned off.
7. After that, you may now install your Microsoft Office Professional Plus 2010 without a problem.
After installing, please don’t forget to turn your User Account Control back on.
