Office 2010 error when uploading
I have a problem when doing a new fixlet for Office 2010 installation using the software distribution wizard.
After doing all the steps and it is time for the upload of software it fails within 15 seconds with an error "Problem occurred when uploading" "file name and path" "Error: HTTP Error 56: Failure when receiving data from the peer". This is only happening on remote console whether the files are locally on the PC or on a file share, when I try it from the server it works without a problem.
The folder that I am trying to upload is 2.6 GB
Have any suggestion then please share some ideas to fix the issue. Thanks.
Error Image:
Error Message:
Message from webpage
File:\ntsaltirislocsourceSMicrosoftOfficeOffice2010ProPlusX32OSB
MUI
122. Design Table
