I am trying to install Office 2007 Enterprise on Windows Vista. I downloaded the installation files from the web but when I run the files I get the error below. Has anyone encountered such an error?
Please provide all steps needed to solve this.
Error – The language of this installation is not supported by system.
Office language error while tried to install
Hello Mr. Shirley,
The problem has many causes possibly. You might have downloaded the East Asian version – Thai or Japanese, though this is very unlikely. So I think your application that tried to extract the source file did not do its job properly. Many a times, utility tools like IsoBuster are not able to carry out full extraction of set-up files from source file. Try extracting using another tool and re-run the set-up files.
Do not use winZip or 7 Zip to extract a .exe file as they should be self extractable. For help on carrying out the self extraction if it doesn’t work normally, click here:
HELP WITH EXTRACTION!!
