Office web Apps Installation Error in Windows 7
Office web Apps Installation Error in Windows 7. Some Features or Role services are required for this product.
I am trying to install office 2007 in Windows 7 but when setup starts after some time below error appears.
I am very confused about this error. Anyone can tell me how can I get rid of this error?
All error details are given below for your understanding.
Setup Errors
Setup is unable to proceed due to the following error(s): This product requires Windows Server 2008 (x64).
Correct the issue(s) listed above and re-run setup.
Answered By 0 points N/A #120894
This is actually a problem with Microsoft SharePoint development. To fix this problem you just have to visit the below web site and copy the files listed in the file and paste them in C:WindowsSystem32 folder.
https://msdn.microsoft.com/en-us/library/ee554869(office.14).aspx
And do a system scan and remove the viruses of the folder and try. The truth is Windows 7 does not support the web apps feature. It is only used for Windows SharePoint 2010 builders. You may have to download and install the below requirements to try this out.
  • Windows 2008 Server x64 SP2 or R2
  • SharePoint Foundation 2010 or SharePoint server 2010
