This is the error when I want to download eBay app for Android from the market on my tablet. I have the same app on my phone and is working just fine without any error. Does anyone have an idea ? Why I cannot download the app from the marker ?
Regards!
Error
“Official eBay Android App” could not be downloaded due an error. (403)
Official eBay Android App could not be downloaded due an error
If you can’t download the eBay Android app on your tablet, try downloading something else and see if the same thing happened. This way you will know if the problem is with your device or with the app you want to download. If other apps can be downloaded and installed on your device then go back to the eBay app page and download it again.
If still it doesn’t work, there is still another way of downloading it if downloading via mobile causes an error. You can download it with your PC. The “Official eBay Android App” you were downloading seems to be different from the “eBay” app available in Google Play. I think this is the problem. That app you want to download is probably from a different developer and not from eBay officially.
First, try visiting eBay Mobile Shopping on your mobile handset and download the eBay app. If downloading the application is successful then install it on your phone. At this point, you no longer need to download the app with a PC.
If you still want to download it with your PC, connect your device to your computer using a USB cable and then visit the link above using your PC. Login to your Google Play account, the same account you used on your mobile phone, and then download the app.
