Often & often asking database update
When I am starting my personal computer there is a message is appearing often which about to update the antivirus database, after updating it when restart my PC again the same message appeared.
So, how can solve it?
Best Answer by Fran Kristopher
Answered By 240 points N/A #169961
Hi Ali,
I believe I can be able to help you with your problem although you didn't specify which anti-virus program you use, you can simply remove the request by going to the settings and changing some of the applied settings.
Go to Settings -> Update -> Manually -> Frequency then change to the intervals you prefer.
Select or click on Ok and the settings will be saved.
I hope this helps.
