I have an old version of 3d album but I now use the current version 3.32. Is it possible for files of my old version of 3d album move to the current version so I can increase performance and quality? I'm on xp 64 bit if that helps. Thanks people.
Old version 3d album move to current version
Hi, a software detects its file by the prototype of the file. Moving from old to new version will not cause an effect to its prototype. For example, a prototype for a document is .doc and we can run any run this type of file in any version of Microsoft office. I think you should create a backup of your files and move to the new version. Thank you.
If you update the program to a higher version, all the old version’s files will be removed and replaced by the new version. That’s how updating works. There will be one or several files left from the previous version after the update but this is if you install the new version over the old version or you install the new version without uninstalling the old version.
But if you uninstall the old version first before you install the new version then everything is new. All files of the program will be from the new version. On the developer’s point of view, updates are done to fix bugs and improve the performance of the application. That’s why it is highly not needed to retain old files from the previous version.
If the new version is compatible with your system then it is recommended to update to this version. You can download 3D-Album 3.32 on Softpedia.
