Re-install software for motherboard on Windows XP
Hello..
I want to know how to complete the re-install of IBM8194A7U motherboard running windows XP so let me know please the steps
thanks for anyone read and answer the question.
Hello..
Here's how to install IBM8194A7U motherboard in detailed steps.
1. Need to install in the right hole, matching holes in the computer case is critical because this might cause overheating if it's not properly seated.
2. A metallic plate will be your guide to where the motherboard should be in placed, holes and screw should be in the spot.
3. Lay down the motherboard, it has holes dedicated for screw and for the metallic frame. Screw the nuts and washer, then tighten up using screw driver.
4. Once in place, install it using the CD driver, and that should be it.
Hope this helps.
