edson chua
10 points
Posted on - 03/05/2012
Can somebody please tell me the most suitable way of syncing my Outlook calendar with my iPhone calendar but not have my events in my iPhone calendar sync with my Outlook calendar?
The outlook calendar is from the office outlook which is shared with my other co-workers, and of course the events in my iPhone is personal, so I would like to be able to have my office outlook calendar on my iPhone but not have my personal calendar in my iPhone be in the office outlook (for obvious reasons). Is there such a thing as one-way sync?
Thanks so much in advance.
One-way Synchronizing between Outlook and iPhone calendars
Do you want to do “One Ways synchronization”?
Yes it is possible and very easy to do.
You have the following given instruction.
For this you required latest software 2.2 installed on your iPhone.
Firstly you must have installed “Google Calendar Sync” and give your all account details in it. You can select what kind of synchronization you want.
Now open settings on your iPhone and Open Mail, Contacts, and Calendars.
Tap Add Account and Select Microsoft Exchange.
Put an account name in the email field (not your actual Gmail). No need to put anything on a domain.
Enter Google's email address and password, and Click Next.
A server field will appear Enter “m.google.com” in this field.
Now click next, it will sync your mobile.
Note: your e-mail account has already configured you need to only select the calendars.
You can add different calendars from different computers; you have to follow the same steps for each computer to sync your iPhone.
You should keep the same profile setting of your iPhone, as everything comes from Google Calendar.
